The tool experienced error
This message occurs when i try to open design (some times ago there was no problem) then “refresh/recalcutes the spines” and the tool falls cyclicaly
Did you get logged out, perhaps? I’ve had it happen where my session expires, but it looks like it’s reticulating splines… but never finishes. Opening in a new tab, I see that I’m logged out. Once I login again, everything is fine. (Close existing tab, open a new one, login, and navigate to the project.)
FWIW, it doesn’t seem to excessively logout. I think my session usually is invalid when I go to a new location(new IP address?) or a very long time has elapsed.
Surprisingly, some of the old projects are working perfectly normal. unfortunately for the second week I can not work with new necessary projects. login and logout has no effects
Can you please send me a link to the designs and I will have the engineering team get them up and running.
https://tools.upverter.com/eda/#tool=schematic,designId=089217e5f75bf1d9
apparently the upverter can not process the board boundaries downloaded from the file
good to hear …
mine is here: https://upverter.com/scalpel4k/3c8fe6860a6c1005/uboot3/
thx Michi
Thanks for your patients, I am having someone look at what is causing this and putting together a fix. I will let you know when I have more information.
any news? it’s still not working …
All my troubles was fixed. Thanks for support.
@scalpel4k I thought this got fixed, I will have it looked at right away
the new update fixed it for me. thanks.
