Solder Junction
Hello,
I am trying to make a 3 or 2 way solder junction in my design, so one can solder connections that could act like a jumper. Im looking for something like this or this.
Does anyone have any ideas on how to do this? I could create a new component, but I think it would be best if this component was placed in the generics category.
I’ve made a few like that for myself in the past. You can probably find them by searching for shunt in the library if that helps.
That said, the best solution would be to just create the part you need, or provide the concierge with enough details on what you need to make it for you. Just name your part something reasonable when you’re making it and anyone else that searches for “3-way solder shunt jumper” will find the part you made and be able to re-use it.
