Serpentine Function not working correctly
When trying to match signal lengths I created a constraint to match certain signals with the serpentine style mitered with a lower amplitude and gap than the original settings (1.27mm amplitude and 0.762mm gap). When I modify the traces, only some of the signals will adjust with the changed amplitude and gap, but others will go by the default setting. Is there a bug with this function or a work around I can do? Thanks!
