Rotating modules not possible
I have created a module which I have imported into a design. I need to rotate it to 10 degrees, but I can only rotate it by 90 degrees.
I tried opening the properties dialog (so I can set the rotation manually), but double clicking the module brings up the board outline dialog. This also happens if the “inspect” button is pressed.
Is there any other way to rotate the module?
