Putting Overscore Line (NOT) on pin names
How do I do this? I have seen many parts created here that have it. And can you also use them in your net names?
Fumbled my way into the answer.
Put an ! in front of your label and it will be “not’ed”
Hi @2-Zons, glad you found the solution! Yes a ! in front of the pin name will add the over-bar
another common way, which I see more on electronics than the ‘!’ which i usually see in code, is to prefix it with a tilde ‘~’ character
