Problem to export schematic of my project
Hello,
I have a problem when I try to export my schematic, not matter if it’s in pdf, svg or png, I have the same error message “Generation in progress. Please try again later”
How can I do to export my schematic ?
Here is the link of my project : https://upverter.com/tvanliefde/6d1ac0002f8cdfc3/Card-power-supply-500W/
Best regards
Thomas
Same problem with exporting to png, hi-res png and pdf. Also export to 3d model seems to be broken.
STL export worked day after.
Do you have any idea when the problem for schematic will be solved ?
Zak from Upverter is addressing it here:
https://www.reddit.com/r/TheAmpHour/comments/53nksn/designs_jammed_inside_upverter_no_exports_in_over/
