Pours connected to the same net not avoiding eachother
I’m having a helluva time getting 2 pours to connect. Usually I can get them to connect when I set the main pour as order 0 and the one being connected (on top?) is order 1 (or anything higher). But this doesn’t always work. I’ve tried various variations of the ordering (tried both the same) but it sometimes connects and sometimes doesn’t. The image below was connected then at some point it stopped. I got it to connect again by playing with the ordering, but I’m having other pours with the same issue.
Update 1
I just reversed the order of the 2 pours in question again and it worked, I had just done this (swapped orders) prior to this post and it did nothing. So it seems to be an intermittent issue.
Update 2
Dang, Just did a repour of everything, broke again. the reorder trick didn’t fix it this time.
Update 3
Sometimes I get this. But not always.
Thanks to the support crew. It was my fault. It was an over-connection problem that took me forever to find since it was with a large ground pour.
