I found a bug (again odd that no none else has gotten this). When I place a via connect to a specific net which goes through 2 pours, and not even connected to one of the pours though the via properties it still connects to that pour even though its not supposed to connect to the layer nor the net.
Here’s a few pictures (tried uploading but they keep going into oblivion when I uploaded them)
View of the error in the layout editor
View of the via settings showing connected net
As you can see the via isn’t connected to the ground layer which has the ground pour. Its connected to VDD_12R0 which is the pink pour, but yet its giving me this error.
to get rid of the error i have to delete the via and reload the editor (otherwise a weird outline persists which the drc thinks its still there)
Further data:
Since I have to manually regenerate the pours every time i do anything and the DRC checker which doesn’t require manual operation, constantly naggs at me until i re-pour, the issue persists for a bit, i have to refresh the screen for the errors to go away or explicitly click the ignore the constraint. I suppose its not so much a bug but a feature change/correction to help sanity.
Further Observations:
Must be a bug. Via’s are associated with nets, pours are being regenerated, refreshing page (after waiting for save), ignoring the constraint. Still gives me the nagging overlay. I would remove the constraints layer, but I’m still working with my rats. Could the rats be their own layer? That would make it easier to ignore errors that aren’t errors until you really want to check them.
