Multiple instances parameter editing in footprint editor
Hello.
Lets assume I have 200 pads in my footprint already assigned, and I need to redefine each pads size. Any solution?
You can select multiple padstacks (not plated through holes yet) and edit their height/width together. Once you’ve selected all of the padstacks you’d like to edit you can press ‘i’ to open the inspector. It’s easiest to only edit pads in the same orientation.
