Hello. I need to position and rotate some components on the PCB in a very specific way. For example, LED1 should be 15 degrees, (x1,y1) coordinates (with accuracy of 0.1mm), LED2 should be 25 degrees, (x2,y2) coordinates, etc. Is this possible in Upverter?
Hi @ntsarb,
Yes, if you go to the component inspector (double click a component, or select a component and press i) you can place a component at a specific location and rotation. Image below.
Hope this helps,
Thank you.
