I need the pour to reach the edges of the board whilst keeping the clearance with the rest of the elements. At present, the clearance is applied to the edges of the board as well.
Thank you!
Thank you!
could you provide the design id?
Hi ESPKit,
What’s your use-case for reaching all the way to the edge of the board? (knowing what you’re trying to do is helpful to try and figure out what the right solution is).
We push back from the board edge intentionally for manufacturability reasons. When the board edge gets cut the router bit or cutting wheel can “smear” the copper along the cut line. This can cause un-intentional shorts between layers that have copper that extends all of the way to the board edge.
Stephen
