How to remove the "more than 3 connections and need explicit name" warning?
I find it quite annoying to have nets highlighted in yellow when they are connected to 3 or more components without an explicit net name. Is there some way to disable this?
OK, answering my own question.
If you go into the constraints settings, in the “schematic rules” section there is a rule called “Named Three Way Connections” which can be turned off and then everything is as I wanted.
Awesome, thank you, you helped me avoid the annoyance.
