Help on 6502! pls
Idk why there are no verified versions of the 6502, and plus, the 6502(the only one) is freaking me out how there are 2 VSS pins and 1 VCC pin. I can’t even find any manual on this thing! pls someone help or make a verified part that is accessible. This would be a lot of help in making my 8-bit.\
if you need u can see my project: https://upverter.com/design/bs12129376/computerorsomething/
noone responding??
The datasheet is actually linked within the component inspector, but here it is. Vss is usually your GND pin, but generically means “the voltage the chip will refer to as Zero Volts”. It’s normal to have multiple GND pins, particularly on MCUs and processors. There’s usually at least one per GPIO bank.
