Project/designID 7df792894ea6b1db
Forked this project, from a project I completed almost a year ago, in order to do a board re-spin. Found two issues in the forked project:
- Components U11, U12 and U13 (same component type) lost a GND connection in schematic and layout after the fork. My main concern is that it could go undetected and there could be other similar problems lurking. How can one audit for this - possible to compare the JSON files?
- Two notes arrows in schematics carried over from old project can’t be deleted (tool crashes and reloads the project when try). No problem deleting a newly created notes arrow created in the forked project.
 Using FireFox on MacOS 10.14.6.
Also wondering if there is a smart way to remove a complete trace between two pins that is routed between layers - manually deleting one segment at a time is slow.
