Error with rotated graphics in gerbers
I wanted to add a few graphics(SVG) to the bottom of one of my boards. In the PCB layout tool everything looks fine but in the generated gerbers the rotated graphics are not placed correctly.
I was able to reproduce the problem in a new project which I included below, along with 2 screenshots.
Upverter:
Exported gerber:
https://upverter.com/Muesli_Reep/0484dbc2697cf33d/SVG-test/
Hi, thanks for reporting this. I really appreciate the reproduction steps/test design!
Just to be sure. The text is being done as an SVG as well as the OSHW logos?
I’ll take a look into the problem and let you know when a fix gets deployed.
Yes, that is correct. The text is also an SVG.
Thank you very much!
I’ve submitted a fix for this to code review. I can hopefully deploy it tomorrow.
The fix is live now. It turns out I was flipping then rotating when I should have been rotating then flipping. Also, I wasn’t rotating around the center of the object. Whoops!
For anyone else reading this that has already exported a Gerber file, you’ll need to make a change to your design (any change, even moving a net and then putting it back) in order to get the latest fixes.
Thank you, @Muesli_Reep for reporting the bug and the excellent reproduction design. That helped a ton!
