Default layer when flipped
can you make it so the default layer is “Bottom Copper” when the view is flipped? hitting ESC after adding a bottom copper trace causes the top copper layer to be selected.
also, can you make it so it selects the corresponding layer when flipping the view? so if you’re currently editing “Top Copper”, flipping the view would automatically select “Bottom Copper” (same for keepout, etc…)
