Bourns PEL12T-4225S-S1024 Discussion
#1
Hello all @parts-specialists @patryk.laskowski
Anyone have any Idea about the following Pin name ?
Please refer the schematic also
anyone have any idea about the pin names. I think it should be
PIN1 = 1_CATHODE
PIN2 = 2_CATHODE
PIN3 = COMMON_ANODE
PIN4 = 3_CATHODE
PIN5 = 4_CATHODE
This is right ???
Please share your suggestion guys
#2
PIN1 = 1_CATHODE
PIN2 = 2_CATHODE
PIN3 = SW
PIN4 = 3_CATHODE
PIN5 = ANODE
Pin 3 looks like a switch, pin 5 is the anode
#3
Actually Pin 1,2,4 are RGB LEDs CATHODEs with pin 5 as Common ANODE terminal. So I Think the name shoud be. It is mentioned at the end of the datasheet.
PIN1 = RED_CATHODE
PIN2 = GREEN_CATHODE
PIN3 = SW
PIN4 = BLUE_CATHODE
PIN5 = ANODE
I didn’t name the pin 3 but I will change its name as suggested by @patryk.laskowski.
#4
@patryk.laskowski
I already made this part with pin 3 name same as its number so I can’t edit it now. kindly provide me the link to edit it.
#5
Hi @ahmedalpha this task is not verified yet. so you can made your changes by finding your part in library.
#6
@Hovhanneskim
#7
@parts-specialists
The pin name-number sequence should be like this.
PIN1 = RED_CATHODE
PIN3 = SW
PIN4 = BLUE_CATHODE
PIN5 = ANODE
PIN6 = MNT_1
PIN7 = MNT_2
PIN8 = A
PIN9 = C
PIN10 = B
#8
Hi @ahmedalpha may I know how do you give number for A as 8, and C as 9. here the signal name should be as a number right ?
#9
I am not very sure about that but I followed the mentioned sequence.
@patryk.laskowski can you suggest us the pin name-number sequence?
#10
PIN1 = 1_CATHODE
PIN2 = 2_CATHODE
PIN3 = SW
PIN4 = 3_CATHODE
PIN5 = ANODE
PIN6 = MNT_1
PIN7 = MNT_2
PINA = A
PINB = B
PINC = C
Hi @ahmedalpha This is my suggestion
#11
PIN1 = 1_CATHODE
PIN2 = 2_CATHODE
PIN3 = SW
PIN4 = 3_CATHODE
PIN5 = ANODE
PIN6 = MNT_1
PIN7 = MNT_2
PINA = A
PINB = B
PINC = C
I would suggest this method as well.
