Hi!
Hope all’s well in Toronto!
I’m working on a board with Cadence 16.6-2015 tools and would like to be able to import it to share with my labmates. I’m hitting the error below after uploading the generated upv and Allegro BRD file.
Regards,
George.
Unexpected import error. | Traceback (most recent call last):
File "/home/ubuntu/builds/20160403010553/eggs/background_workers-201603132855_12c5e5cd-py2.7.egg/background_workers/handlers/import_file.py", line 326, in work
File "/usr/lib/python2.7/dist-packages/upconvert/upconverter.py", line 159, in file_to_upv
design = Upconverter.parse_brd(brd_tmp_path, brd_fmt, design, args)
File "/usr/lib/python2.7/dist-packages/upconvert/upconverter.py", line 105, in parse_brd
design = par.parse(in_filename)
File "/usr/lib/python2.7/dist-packages/upconvert/parser/zipfile_parser.py", line 162, in parse
results = self.parse_files(detected_files, brd_files)
File "/usr/lib/python2.7/dist-packages/upconvert/parser/zipfile_parser.py", line 101, in parse_files
results.append(parser.parse(files))
File "/usr/lib/python2.7/dist-packages/upconvert/parser/allegro/allegro.py", line 79, in parse
layout.attach_footprints(self.design, records, negative_shapes)
File "/usr/lib/python2.7/dist-packages/upconvert/parser/allegro/layout.py", line 274, in attach_footprints
unit_multiplier, negative_shapes, get_pin_connections)
File "/usr/lib/python2.7/dist-packages/upconvert/parser/allegro/layout.py", line 342, in create_footprint
for via in create_hole(hole_geometry['VIA CLASS'][refdes], 0, 0, unit_multiplier,
KeyError: 'C1'
