[resolved] MikroBUS templates for contest
I’ve been trying to base a design off the MikroBUS “large” template from this posting by Anandh Venkateswaran. Unfortunately the large template seems to in fact be based on a small card’s dimensions.
Ideally, I shouldn’t have to make the card form factor choice up-front, as I’m not sure what it will take to layout my card at concept time.
Apologies if I’ve mentioned this before and missed your response.
Hi Burt, thanks for pointing this out. I fixed the links.
The correct link for the Large template is: https://upverter.com/yashwanth/9445a8429ddbee22/Mikrobus-add-on-board-L/
Anandh
Thank you Anand.
Is there a reason these are projects and not modules?
I’m going to give a shot at converting one to a module. It seems like that way if I needed to switch from say a Large layout board to a Medium, it would be easier to do without re-forking.
